How to start DCO desktop client in a different language
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • How to start DCO desktop client in a different language
126
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-04 01:39 AM . Last Modified: β€Ž2024-04-05 04:04 AM
793
Data Center Operation (DCO) desktop client is available in eleven languages. By default, the client will launch in the language of the clients operating system. However, it is possible to start the client in a different language.
This can be specially useful for non-English clients, that would like to report issues or ask questions in an international space (such as this Community) or tech support.
Locate the configuration file: "StruxureWare Data Center Operation.ini"
(for Windows usually located in (C:) Program Files\StruxureWare Data Center Operation 'version'\application)
Edit the configuration file (via Notepad or similar), and add the following two lines (right after -clean)
-nl
'Country Code'
and save the file.
Here is an example to configure/run it in English (en):
Now the DCO client will start in the specified language (English in this example).
To undo: Either remove those entries or add # (to start of those lines), and then save the file.
A different approach/method is also described here: Starting StruxureWare Data Center Operation Client in a Different Language
Kind regards
(CID:126172430)
  • Data Center Operation
Thanks for sharing Jef Faridi! πŸ˜€
(CID:126173343)
You are most welcome, Ditte πŸ˜€
Kind regards
(CID:126173356)
Posted: β€Ž2020-07-04 01:39 AM . Last Modified: β€Ž2023-10-22 02:35 AM
