Posted: 2020-07-02 04:12 PM . Last Modified: 2024-04-09 02:53 AM
Generic PDU is not possible single-phase
Breakers 1P
Generic rPDU 1P. The power dependency is ok (breaker 1P = L1)
I can't set the phase to the device. why...? where am I wrong?
(CID:103584795)
Hi Roberto,
Currently DCO dose not support modeling a single phase UPS/PDU. (the support of single phase/direct current is expected to be included in one of the future releases).
The reason why you are not able to connect the IT-device to your rack pdu, is because your IT-device is expecting 230V/50Hz (as Input Voltage), but your PDU is providing 380V/50Hz (as Output voltage). You need to change the output voltage for your PDU to 400/50 (from 380/50), then you should be able to continue the power cable connection for your IT-device(s).
Kind regards
(CID:103584810)
Hello Roberto, Please correct me if I am wrong by the genome that you have selected is a distribution/floor mount PDU which does not support single phase power. Rack mount PDUs can support single phase power. Can you please describe the PDU that you are looking to model so we can provide best way to model your build the best way possible. Thanks Victor
(CID:103584807)
Hi Roberto,
Kind regards
(CID:103584810)
Resolved.
Thank you.
Kind regards.
(CID:103584883)
Posted: 2020-07-02 04:13 PM . Last Modified: 2024-04-09 02:53 AM
Hi Roberto, My pleasure - thank you for taking the time and letting us know that it is resolved. Kind regards
(CID:103584890)
Posted: 2020-07-02 04:13 PM . Last Modified: 2023-10-31 11:07 PM
