Posted: 2020-07-02 04:12 PM . Last Modified: 2024-04-09 02:53 AM
I have a Cooling Device in DCE which lists a lot of temperature points however when I go to device association in DCO no points are coming across, as far as I can tell its not a DDF issue as all the points are in DCE. Is this a known error or is there something else I have to do to get the temperature points over to DCO?
(CID:103584770)
Hi James,
Most likely the "supported" temperature sensors are not being reported as expected to DCO (from DCE). DCO expects temperature sensors of type:
Temperature Sensors:
EXTERNAL_TEMPERATURE
SUPPLY_AIR_TEMPERATURE
RETURN_AIR_TEMPERATURE
INTEGRATED_TEMPERATURE
More description available here: http://dcimsupport.apc.com/display/DCIMDEVELOPER/DCE+Sensor+Mapping+to+DCO
I think, you might need to get new DDF file(s) from the multivendor support team ( multivendorsupport@apcc.com ) .
Kind regards
(CID:103584772)
Posted: 2020-07-02 04:12 PM . Last Modified: 2023-10-31 10:21 PM
