How to resolve the mismatch between the DCO(KWH) and DCE (KWH)
  • EcoStruxure IT forum
  • How to resolve the mismatch between the DCO(KWH) and DCE (KWH)
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 03:46 PM . Last Modified: ‎2024-04-09 03:02 AM
727
I discovered after comparing the KWH value of DCO and KWH value of DCE of a particular rack and time are greatly different.
(CID:102925128)
  • Data Center Operation
Replies 10
Hi Oloruntobi, Would it be possible for you to share some screen captures (from DCE and DCO) illustrating how the data is being compared, thanks.
(CID:102925130)
Posted: ‎2020-07-02 03:47 PM . Last Modified: ‎2024-04-09 03:02 AM
Hello Jef Faridi,
Thank you for your response and your kindness to assist. Please, which ID or how do you want me to send the attachment of the DCO and DCE as I can not see how to attach files on this platform.
Best regards,
Oloruntobi.
(CID:102925151)
Please, how can I send the attachment to you?
(CID:102925152)
Hi Oloruntobi, You are right, currently it is not possible to attach files to this "COMMENT" section, but it is possible to add attachments/images under "YOUR ANSWER" (or the posted question) section. Kind regards
(CID:110017385)
Hi Jef Faridi,
Thanks for the idea, Please see the attached as requested. The file name (DCE) PDF AB Module 4 line 3 is the KWH obtained using DCE while (DCO) Module 4 line 3 was the KWH obtained using DCO.
Oloruntobi.
(DCE) PDF AB Module 4 line 3.csv (DCO) Module 4 line 3 ( Schneider community)1.pdf
(CID:103583762)
727
Hi Oloruntobi,
Apparently your rack pdu power info is not being reported correctly to DCO. It has been a known issue that some rack pdu's power bank info is not being reported correctly to DCO.  For detail description please see the following page:
http://dcimsupport.apc.com/display/public/UAOp74/Correcting+False+Power+Values+Reported+by+StruxureW...
(CID:102925218)
Hi Oloruntobi, Many thanks, I'm currently reading the files, I will get back to you soon, thanks.
(CID:103583755)
Hi Jef,
Thanks for the link and assistance, we will try this and give you feedback.
Best regards,
Oloruntobi.
(CID:102925268)
   Hi Jef,
Thank you so much for your efforts to assist. Please see the attachments below, they might also be useful for better analysis. All attachment are for the month of August.
Dco 1st August to 31st August n.pdfDco 1st August to 31st August n.pdf
Oloruntobi.
(CID:103583763)
Posted: ‎2020-07-02 03:47 PM . Last Modified: ‎2023-10-31 11:07 PM
