How to reset DCO web login Password
  • EcoStruxure IT forum
  • How to reset DCO web login Password
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:07 PM . Last Modified: ‎2024-04-05 12:19 AM
1613
I know the username and password i am entering are correct, however the system is telling me that the credentials are wrong.
How do i reset these credentials without having to reinstall a new DCO server?
(CID:130091026)
  • Data Center Operation
1613
Hi Martin,
If I understand correctly it is concerning the log in to DCO webmin interface, right?
If yes, then please see the instructions here: Resetting user password on the DCO server
Kind regards
(CID:130091754)
Replies 9
Dear Martin Parks,
This problem has already been discussed repeatedly on EcoStruxure IT (see, for example Password Reset for DCO user client, Recovery password DCO 7.4 and DCO password recovery). And as Jef Faridi wrote in post Password Reset for DCO user client:
I will contact you (by direct email) soon and we will resolve this off-line. But I wish to let you/Community know that this is not a usual support, it is expected that the customer(s) take the responsibility of taken care of the system credentials.
Therefore, you need to wait for help from EcoStruxure IT Support team.
Always glad to answer your questions.
(CID:130091742)
1614
Hi Martin,
Kind regards
(CID:130091754)
Jef Faridi
Thank you for the reply, i have ran through the above, and it appears that the account which i initially set up is no longer present.
Is there a command i can use to list the accounts which are present on the system? this will help me identify what the account name has been changed too.
Martin
(CID:130092183)
Hi Martin,
You are welcome, The file "/etc/passwd" should contain the possible user name(s), so you can use less or cat to display its content:
cat /etc/passwd
(note: this file may not be manually modified!)
Kind regards
(CID:130092186)
Hi Jef,
Thank you for the command above, I have ran this and can see the user accounts on there.
is it possible you can send me an email? so i can send you a picture of what is coming up?
(CID:130092797)
Hi Martin,
Please check your email box, thanks.
Kind regards
(CID:130092852)
Posted: ‎2020-07-04 04:08 PM . Last Modified: ‎2024-04-05 12:19 AM
Hi Martin,
Short update to share with all that issue is resolved - you've managed to restore the whole server from a backup rather than just the database.
Kind regards
(CID:130093438)
Thank you for your reply 😀
(CID:130091919)
Posted: ‎2020-07-04 04:08 PM . Last Modified: ‎2023-10-22 02:34 AM
This is a heading
