How to install DCO-8.2.2 on a UEFI-based systems physical
Showing results forย
Did you mean:ย
  • EcoStruxure IT forum
  • How to install DCO-8.2.2 on a UEFI-based systems physical
125
65
Back to EcoStruxure IT forum
Posted: โ€Ž2020-07-04 04:08 PM . Last Modified: โ€Ž2024-04-05 12:19 AM
929
Hi team
I am installing DCO 8.2.2 on an HP Proliant ML350d computer from a bootable usb and it shows me the following message
reason why that kind of error message comes out
hp server features
Norberto
(CID:130091340)
  • Data Center Operation
Replies 5
Dear Norberto Castillo,
It seems to me, that maybe the problem is how your boot flash drive with the DCO software image was created. Therefore, I highly recommend, that you try to install the DCO software from a normal bootable iso-image (be sure to check its checksum).
This can be done either with a standard internal/external CD/DVD drive or using the capabilities of the iLO adapter (unless of course your server has it). How to do this is described in the tips  and
I hope this helps you.
With respect.
(CID:130091704)
Have you been able to solve your problem, or do you have any more questions about it?
With respect.
(CID:130680486)
I already managed to install it on hp server through ilo thanks for the help.
regards
(CID:130680928)
Ok, thank you for the feedback ๐Ÿ˜€.
(CID:130680977)
Posted: โ€Ž2020-07-04 04:09 PM . Last Modified: โ€Ž2023-10-22 02:31 AM
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
