Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-05 08:45 PM . Last Modified: 2024-04-03 01:06 AM
Dear support,
Explain, please, how can I make a request DDF modification such as for Symmetra PX250/500? I could not find a simple way ☹️.
This is very necessary to do, since I discovered a lot of errors in the apcsmartups.xml v.103 DDF-file after installing DCE-7.7. The errors relate to the Symmetra PX250/500 UPS, and because of this I had to go back to the old, but correct DDF-file apcsmartups.xml v.99.
Waiting for your reply.
Very thanks for the support.
(CID:147196003)
Hi Spezialist,
Please visit this page: https://ddf.ecostruxureit.com/. After you search for something (anything), you can click the "request" button and report the issues there. Please include an SNMP walk of the device, plus a screenshot showing the errors.
Thank you for letting us know what needs to be fixed.
Jake
(CID:147196062)
Hi Spezialist,
Jake
(CID:147196062)
Dear Jake Hiltz,
Ok, thanks for the answer: I'll let you know about the result.
(CID:147196072)
Dear Jake Hiltz,
Thanks for the help, I was able to create a request for modifying the DDF-file.
(CID:147197026)
Dear support,
I have to notify you, that unfortunately the same problem is observed in the new version of DCE-7.7.1 ☹️.
(CID:148771776)
Posted: 2020-07-05 08:45 PM . Last Modified: 2023-10-22 02:33 AM
