How to remove duplicate sensors Netbotz 355 using Advanced View
  • How to remove duplicate sensors Netbotz 355 using Advanced View
129
72
Posted: ‎2020-07-05 08:28 PM . Last Modified: ‎2024-04-03 01:12 AM
737
We moved a 455 wall monitor to a new location where it is stand alone.  Duplicate sensors now show up in the pod list with a (1) behind the name.  How do we remove those?
(CID:146670579)
  • NetBotz
Hi Jim,
The only reason you should have duplicates is if you connected the sensors to different ports. In this case, one sensor should be in an OK state and one should be disconnected. Here you can see I have 2 sensors in a failed state:
If I right click on one of them and choose configure sensor:
I have the option to remove this sensor:
If I select a sensor that is still connected, that "Remove" option will be grayed out.
Steve
(CID:146670793)
Posted: ‎2020-07-05 08:28 PM . Last Modified: ‎2023-10-22 02:33 AM
