How to read current temperature with SNMP ?
  • How to read current temperature with SNMP ?
126
65
Posted: ‎2020-07-05 07:50 PM . Last Modified: ‎2024-04-03 02:31 AM
1689
I am using MIB Browser and have loaded the PowerNet MIB. I managed to get some parameters of the MIB (under the apcmgmt folder), however it does not work for SNMP objects under the products folder (object not found).
I would like to be able to read with SNMP "gets" the status of my sensors (temperature, humidity, doors status open/closed). Could you please help me to do so ?
(CID:144314080)
  • NetBotz
  • bug
Replies 5
Posted: ‎2020-07-05 07:50 PM . Last Modified: ‎2024-04-03 02:30 AM
1689
Hi Laurent,
Before looking for the correct OID, we'd need to know what product you're using and what sensors.
Steve
(CID:144314139)
Hello Steve
I have the Netbotz 250 (model NBRK0250, HW Rev 05, FW Rev 0.7.6).
The wired sensors are
- door switch : NBES0302
- Temperature and humidity : AP9335TH APC.
Regards
Laurent
(CID:144868354)
By chance I have been able to find the information into the MIB.
The doors sensors status can be fetched in the table : memDoorsSensorsStatusTable.
The temperature / humidity sensor status can be read under : memSensorsStatusTable.
Both are tables so a snmptable command must be used.
Regards
(CID:144868352)
Posted: ‎2020-07-05 07:51 PM . Last Modified: ‎2024-04-03 02:30 AM
Thank you for the support
(CID:144868356)
Posted: ‎2020-07-05 07:51 PM . Last Modified: ‎2023-10-22 02:33 AM
