Posted: 2020-07-02 10:33 PM . Last Modified: 2024-04-09 01:25 AM
I have customer who wants to use Insight on their test/dev DCO server and then publish to their production DCO server. How do we do this?
(CID:105460874)
Hi Ed Tarento
The need to save the report design in Insight and then follow the below instructions:
In StruxureWare Data Center Operation, import the custom report design.
Jesper
(CID:105460885)
Hi Ed Tarento
Jesper
(CID:105460885)
Adding one additional comment to Jesper's above response. When Insight is launched the user must logon to a DCO server. That server is the server to which the Insight report will be published... so if you develop an insight report on a test DCO server, the user will use the test DCO server name and logon credentials to test the report, once they are ready to publish the report to the prod server they can logon to Insight using the prod server host info and credentials, pre-test/preview the report against the prod environment and then publish the report to the prod server. I should note, if you are using an ETL export database it will likely be necessary for the user to update their data source info to point to the export database for the prod server... otherwise the report will look at the export database from the test server. Regards Greg Sterling
(CID:105460935)
Posted: 2020-07-02 10:33 PM . Last Modified: 2023-10-31 11:06 PM
