How to migrate from a DCO standalone to a DCO cluster?
  • How to migrate from a DCO standalone to a DCO cluster?
129
72
Posted: ‎2020-07-04 06:39 PM . Last Modified: ‎2024-04-04 11:28 PM
785
We have a DCO standalone v8.0.1.
Can I install two DCO as cluster v8.2.2 and then restore the backup v8.0.1 ?
Do I have to restore it twice (on both) ?
(CID:132650292)
  • Data Center Operation
Posted: ‎2020-07-04 06:40 PM . Last Modified: ‎2024-04-04 11:28 PM
Hi Eduard!
Please keep in mind that cluster feature may not work as you expected because 8.2.2 is optimized for standalone configuration. So it's recommended to use Standalone+DR node configuration.
I could recommend you to check topic for instructions.
After deploying you should restore backup on master node and it will be synced to DR node automatically.
(CID:132650391)
Hi Eduard!
(CID:132650391)
Posted: ‎2020-07-04 06:40 PM . Last Modified: ‎2023-10-22 02:32 AM
