How to get phase info for racks, rdus, UPSs via SXW Insight
  • How to get phase info for racks, rdus, UPSs via SXW Insight
129
72
Posted: ‎2020-07-02 10:28 PM . Last Modified: ‎2024-04-09 01:27 AM
911
I want to report in phase balancing and am looking for some raw data in DCO.  I can see CONFIGURATION_ITEM_POWER_PATH and pp_average_power but I'm not sure exactly what it means.
Where else in DCO 7.5 ETL Export DB might I find the data?
(CID:105460658)
  • Data Center Operation
Hi Ed,
Remember, you won't find any historical data in the export db.
Otherwise you are looking at the right table (configuration_item_power_path), and both peak values (pp_peak_power) and average values (pp_average_power) are available for each phase.
You should have a value similar result than this one: #L1:756.0 #L2:432.0 #L3:456.0 which means 756Watts on phase 1, 432Watts on phase 2 and 456Watts on phase 3. You will need a little bit of scripting to extract the values from the string in your report engine. Note that "NaN" means we don't have measurement for the corresponding phase.
To my knowledge this data is not exposed today via web-services.
-Guillaume
(CID:105461825)
Replies 5
Hi Ed Tarento, thank you for posting. Let's see who can be of assistance here. @community any ideas? Best, Stine
(CID:105461736)
Hi Ed,
-Guillaume
(CID:105461825)
Posted: ‎2020-07-02 10:28 PM . Last Modified: ‎2024-04-09 01:26 AM
911
Thanks Guillaume
A Javascript Event Handler in the BIRT report?
(CID:105467065)
Hi Ed, You can script either the data set by adding a computed column or the data cell in your table. Here is an example that would work if you expect only single phase measurements (replace "peak_power" by the name of your column): var result=0; if(dataSetRow["peak_power"] != null){ var javaString = (new Packages.java.lang.String(dataSetRow["peak_power"])); var cleaned = javaString.replace('","', "").replace("{", "").replace("}", "").replace("NULL", "0").replace('"#L1:', "").replace("#L1:", "").replace(" #L2:", ",").replace(" #L3:", ",").replace('";', "").replace("NaN", "0").replace(',"', ""); var splitted=cleaned.split(","); for (var i=0; i
(CID:105467117)
Posted: ‎2020-07-02 10:28 PM . Last Modified: ‎2023-10-31 11:05 PM
