Posted: 2020-07-03 08:15 AM . Last Modified: 2024-04-08 03:56 AM
I want a ddf file for an equipment that is already listed in the device support for "supported" with DCE. What exactly is the process to get the ddf for that; whether I need to go to the "Request change to support" or "Request device support" as I couldn't find any other way around to request for an already supported equipment's ddf. Thanks
(CID:110005823)
Posted: 2020-07-03 08:16 AM . Last Modified: 2024-04-08 03:56 AM
Hello Irfan,
Please go to "Device Support", search for the device you are looking for and we have an option "i want it too" which can be used to request a DDF for an existing device.
Thanks and Regards,
Ganga Rajagopal
(CID:110006058)
Hello Irfan,
Thanks and Regards,
Ganga Rajagopal
(CID:110006058)
Thanks for your kind response.
(CID:110006275)
Posted: 2020-07-03 08:16 AM . Last Modified: 2023-10-22 02:30 AM
