How to create a cage from 3 mesh walls and the data center wall?
  • How to create a cage from 3 mesh walls and the data center wall?
129
72
Posted: ‎2020-07-04 02:10 PM . Last Modified: ‎2024-04-05 02:43 AM
797
How do I create a cage from 3 mesh walls and the data center wall?
(CID:128755864)
  • Data Center Operation
Replies 5
Posted: ‎2020-07-04 02:11 PM . Last Modified: ‎2024-04-05 02:43 AM
797
Hi Daniel,
Thanks for Posting here. I came up with 2 scenario here
Scenario 1) You just need to right click on the wall which you need to edit. As shown in image
(3D view)
Scenario 2) You just need to use draw wall tool as shown in below screenshot.
(3D view)
Regards.
(CID:128755918)
Yes, I'm doing the 2nd scenario, but after the cage is constructed there is no "Create Cage" option in the right-click menu. We use Colo.
(CID:128757471)
Hi Daniel,
Got your point. We don't support that scenario now. Will create a report for it. Will let you know when its fixed. (DCO-10239).
Regards.
(CID:128757473)
Hi all,
Update:
Engineering team have reviewed the codes, you will have to create a closed wall set without room walls in order to be able to create a cage. So basically it works as designed.
Kind regards
(CID:128757478)
Posted: ‎2020-07-04 02:11 PM . Last Modified: ‎2023-10-22 02:28 AM
