Continue
  • My Subscriptions
  • Events
How to create a cage from 3 mesh walls and the data center wall?
EcoStruxure IT Forum
  • Re: How to create a cage from 3 mesh walls and the data center wall?
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 02:10 PM . Last Modified: ‎2024-04-05 02:43 AM
1147
How do I create a cage from 3 mesh walls and the data center wall?
(CID:128755864)
  • Data Center Operation
Replies 5
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 02:11 PM . Last Modified: ‎2024-04-05 02:43 AM
1147
Hi Daniel,
Thanks for Posting here. I came up with 2 scenario here
Scenario 1) You just need to right click on the wall which you need to edit. As shown in image
(3D view)
Scenario 2) You just need to use draw wall tool as shown in below screenshot.
(3D view)
Regards.
(CID:128755918)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Yes, I'm doing the 2nd scenario, but after the cage is constructed there is no "Create Cage" option in the right-click menu. We use Colo.
(CID:128757471)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Daniel,
Got your point. We don't support that scenario now. Will create a report for it. Will let you know when its fixed. (DCO-10239).
Regards.
(CID:128757473)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi all,
Update:
Engineering team have reviewed the codes, you will have to create a closed wall set without room walls in order to be able to create a cage. So basically it works as designed.
Kind regards
(CID:128757478)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 02:11 PM . Last Modified: ‎2023-10-22 02:28 AM
