How to configure two UPSs as one UPS in DCO 8.1?
  • EcoStruxure IT forum
  • How to configure two UPSs as one UPS in DCO 8.1?
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 01:42 AM . Last Modified: ‎2024-04-05 04:03 AM
1102
Dear Expetrs,
The customer has 1 symmetra UPS 500 acts as UPS B and Two symmetra UPS 250 act as UPS A how to configure the two UPSs 250 to act as UPS A in DCO 8.1?
BR,
Sameeh
(CID:126172996)
  • Data Center Operation
Replies 6
Hi Sameeh ahmad, thanks for posting. Let's hope you find your answer here.
Kind regards
Ditte
(CID:126173358)
1102
Hi Sameeth,
Not sure I understand what it means exactly by two UPSs to act as one, serial addition of two units or parallel? I don't think that's directly supported in DCO. I think in either case a possible work around might be to create a single UPS.
Kind regards
(CID:126173455)
Hi Jeff,
There are two UPSs 250KW working in paralle. and these two 250KW UPSs are working in parallel with 500KW UPS.
If I replaced the two UPSs 250 KW by a single UPS 500KW I will not be able to associate the UPSs correctly, what do you recommend ?
BR,
Sameeh
(CID:126173536)
As Jef Faridi suggested, if the UPS are configured in parallel, you should model them as one UPS in DCO (with the combined capacity of the two UPSs - 500KW).
In order to get the associations from DCE to work, I would create a UPS object with zero capacity and a small form factor, and then place that next to the big UPS in DCO. That way, you get a UPS object where you can associate DCE alarms.
Hope this helps.
/Christian
(CID:126173742)
Thanks Christian for your reply, I'll follow your recommendation.
BR,
Sameeh
(CID:126173763)
Posted: ‎2020-07-04 01:42 AM . Last Modified: ‎2023-10-22 02:28 AM
