How to configure a second network port on DCO server?
  • EcoStruxure IT forum
  • How to configure a second network port on DCO server?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:41 AM . Last Modified: ‎2024-04-09 12:51 AM
914
I created a second port in order to access server from two different networks (1 non routed and 1 routed). On this second interface, I am able to access the web page (to get the client and configure the server), but my client freeze during the loading process). However, if I try my client on the non routed network (the first one), I have no problem.
MISSING IMAGE: Capture d’écran 2016-03-04 à 11.49.19.png
(CID:105467782)
  • Data Center Operation
Replies 8
914
Hi Thomas,
As far as I know, currently DCO doesn't support the configuration of a second interface (NIC). I believe I have recently registered a similar feature request, I can go ahead and add you to that case if it's okay with you, thanks.
Kind regards
(CID:105467784)
Yes. Go head and add me to that case.
(CID:105467787)
Hi Thomas, Done! You are now added to that case, thanks. Kind regards
(CID:105467788)
I would find this beneficial also. Is this possible with DCO 8.0? Thanks
(CID:106892627)
Hi Tony, Many thanks for your comment, you are now added to the existing feature request. And to answer the question, that is not supported with DCO 8.0. Kind regards
(CID:107448131)
Posted: ‎2020-07-03 12:42 AM . Last Modified: ‎2024-04-09 12:51 AM
Does anyone know if this is still not supported with DCO? I have a customer looking to do the same thing.
(CID:125212913)
Hi Mark,
As far as I know this is still unsupported.
Kind regards
(CID:125212919)
Posted: ‎2020-07-03 12:42 AM . Last Modified: ‎2023-10-31 11:04 PM
