How to change Hostname in DCE
  • How to change Hostname in DCE
129
72
Posted: ‎2020-07-02 09:56 PM . Last Modified: ‎2024-04-09 01:37 AM
1841
    I want to change hostname from IP address to text naming.  right know DCE showing IP on hostname column. kindly describe the procedure how to change the hostname, even don't have DNS and client IP scheme.
Ali.
(CID:105459742)
  • Data Center Operation
  • NetBotz
Replies 5
1841
Hi Ali!
DCE takes "Hostname" values from devices via SNMP, so only way to change it is go to the device and set it up. You can add additional property in DCE and name all devices as you want.
(CID:105459761)
hi valentine, I put the hostname on device but it is not showing on DCE.
(CID:105459771)
Posted: ‎2020-07-02 09:56 PM . Last Modified: ‎2024-04-09 01:36 AM
mr ,will you get any solution about this plz share ..
(CID:108828273)
Hi Ali,
This issue is discussed in our KBase FA267667.
Issue:
Hostname field within StruxureWare Data Center Expert displays the IP address of a device and not the Hostname
Product Line:
Environment:
Any version
Cause:
After adding a device into StruxureWare Data Center Expert it may display the IP address within the hostname field.
Resolution:
StruxureWare Data Center Expert will put the IP address of a device into the hostname field if it is unable to look-up the IP address of the device within your DNS server to obtain the hostname.  To correct the issue, please make sure that there are entries within your DNS server for the device. This may require both forward and reverse lookups. You can verify your DNS settings within StruxureWare Data Center Expert under: System > Server Administration Settings > Network Settings.
Hope this helps.
Regards
(CID:105459808)
Posted: ‎2020-07-02 09:57 PM . Last Modified: ‎2023-10-31 11:04 PM
