Posted: 2020-07-02 10:25 PM . Last Modified: 2024-04-09 01:27 AM
Hi Team,
We have a customer with 2000+ work orders, most of them are completed. This long list of work orders takes up a lot of space in the work order view, which can only show 1000 work orders at a time.
Is there a way to archive completed work orders, for instance by date?
One possible work around would be to move them to a Project, e.g. Archive Completed 2015 and then use this as a filter, but I can't find a way to bulk change the work order project code on multiple work orders.
Any ideas?
Christian
(CID:105460591)
Christian Riis Could you use the Status filter and change it to show Not Started and In Progres tickets?
(CID:105460698)
That might do the trick. I'll suggest this to the customer.
(CID:105460699)
Posted: 2020-07-02 10:26 PM . Last Modified: 2024-04-09 01:27 AM
Hi, Our problem is not viewing the tickets. The problem is number of tickets are growing in huge numbers and i dont want to see them all the times. I want to see for example last one months tickets in the main screen. Regards,
(CID:105460709)
Posted: 2020-07-02 10:26 PM . Last Modified: 2023-10-31 11:03 PM
