How to add a customer in DCO Co-Lo without CRM?
  • EcoStruxure IT forum
  • How to add a customer in DCO Co-Lo without CRM?
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 02:08 PM . Last Modified: ‎2024-04-08 01:24 AM
1045
The manual only describes the integration with a CRM application.
What if this it is not an option? We can not use customers in Co-Lo?
(CID:114234072)
  • Data Center Operation
Replies 5
Posted: ‎2020-07-03 02:09 PM . Last Modified: ‎2024-04-08 01:24 AM
1045
Hi Eduard,
Manually adding/removing customers can be done through web services that is described here: https://dcimsupport.apc.com/display/public/DCIMDEVELOPER/Customer+Web+Service
The description (3rd line in your screen capture) contains the link as well, it says see " Customer Web Service ".
Kind regards
(CID:114234168)
Hi Jef,
I followed the video tutorial. But get blocked when loading WDSL
I have the colo license:
and the user automation as been created:
What could be the reason?
(CID:115345124)
Posted: ‎2020-07-03 02:09 PM . Last Modified: ‎2024-04-08 01:23 AM
Hi Eduard,
For DCO 8.x, you might want to use the Customer REST web service ("POST / Customer" option is to add customer). As Kresten mentioned, the documentation is available here: https://dcimsupport.apc.com/DCOAPIdoc/
You can access the REST web service api by typing in the following URL:
https:///api/current/docs/index.html
Where is the name or ip address of your server.
Kind regards
(CID:116361902)
If you are using DCO 8+ I would recommend using the Customer REST web service instead. The documentation is available here https://dcimsupport.apc.com/DCOAPIdoc/
The APIs are being transitioned from SOAP to REST
(CID:114234366)
Posted: ‎2020-07-03 02:09 PM . Last Modified: ‎2023-10-22 02:25 AM
