DCO & moving virtual machines to non-impacted areas
  • EcoStruxure IT forum
  • DCO & moving virtual machines to non-impacted areas
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 02:08 PM . Last Modified: ‎2024-04-08 01:24 AM
742
Hi Team, DCO is aware of critical physical infrastructure alarms and events and can execute corrective actions to move virtual machines to non-impacted areas within the data center. We need DCE to trigger those alarms BUT can we also use other tools then DCE, for example PRTG ??
please advice
(CID:114233777)
  • Data Center Operation
Hi Cees,
As far as I know, integration with other tools (such as PRTG) is unsupported.
I guess you might be referring to "PRO Pack", as described here: StruxureWare Data Center Operation: PRO Pack
"The PRO-enabled management pack ensures Virtual Machine Manager is aware of critical physical infrastructure alarms and events and can execute corrective actions to move virtual machines to non-impacted areas within the data center."
Kind regards
(CID:114821303)
Hi Cees,
Kind regards
(CID:114821303)
Posted: ‎2020-07-03 02:08 PM . Last Modified: ‎2023-10-22 01:44 AM
