  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Energy & Sustainability Services
      • Green Building Scoring and Certification Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Remote Operations Devices Knowledge Base
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • Active Energy Management Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
How to add DCO CPU resources?
A support forum for Data Center Operation, Data Center Expert, and EcoStruxure IT product users to share knowledge on installation, configuration, and general product use.
  • Communities
  • How to add DCO CPU resources?
  • Subscribe to RSS Feed
Send a co-worker an invite to the Exchange portal.Just enter their email address and we?ll connect them to register. After joining, they will belong to the same company.
Captain Jef Captain
76
Commander APC_Steve Commander
54
Commander gsterling Commander
49
Lt. Commander Cory_McDonald Lt. Commander
15
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 06:36 PM
699
This question was originally posted on DCIM Support by Yonker Wang on 2017-08-03
DCO Slow response . Restart DCO one time, it costs about 4 hours.
If Two users log in at the same time, One of them cannot load the Client view.
Check the system, The CPU is used 210% always in DCO , below.
(CID:123343894)
  • Data Center Operation
699
This answer was originally posted on DCIM Support by spezialist on 2017-08-03
Hi Yonker Wang,
Most likely you have DCO-server working as a VMware VM appliance. Therefore, firstly, it is necessary to check whether the hardware resources allocated to your DCO VM correspond to the minimum requirements that can be found on the page Recommended StruxureWare Data Center Operation server configuration:
Server requirement guidelines (minimum)
  • CPU: 4 cores minimum. We recommend 8 cores
  • Memory: 16 GB RAM (absolute minimum requirement)
  • 100 GB storage, speed minimum 170 MB/s
  • Cluster network: 1 Gbps connection between nodes
  • Disaster recovery network: 10 Mbps with low latency <100 ms
If your'e installing DCO on an existing server, note that DCO claims almost all memory (JVM about 8 GB and Postgres about 6 GB alone). Therefore, you may experience issues if you have other applications running on the server, such as surveillance and monitoring agents.
If this is not the case, you should contact your VMware administrators to allocate the missing hardware resources for the DCO VM.
With respect.
(CID:123343908)
Replies 6
700
Hi Yonker Wang,
With respect.
(CID:123343908)
This comment was originally posted on DCIM Support by Yonker Wang on 2017-08-04
Thanks for your help~!
(CID:123344284)
Posted: ‎2020-07-03 06:37 PM
This comment was originally posted on DCIM Support by spezialist on 2017-08-04
Hi Yonker Wang,
Thanks for the feedback: it will be very useful if you let us know whether the problem is solved or not.
With respect.
(CID:123344286)
This comment was originally posted on DCIM Support by Yonker Wang on 2017-08-07
Hi team,
We reinstalled the DCO, give the DCO more Resources, according to Server requirement guidelines (minimum) , have solved the problem.
(CID:123344738)
This comment was originally posted on DCIM Support by spezialist on 2017-08-07
Hi Yonker Wang,
Thank you for your feedback.
With respect.
(CID:123344792)
You can subscribe to this forum after you log in or create your free account.
Already have an account?Login
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
