How to access eth0 and eth1LAN card in same time
  • How to access eth0 and eth1LAN card in same time
129
72
Posted: ‎2020-07-02 09:41 PM . Last Modified: ‎2024-04-09 01:42 AM
785
    I have configured two LAN card in DCO 7.5  . eth0 have 192.168 and eth1 have 10.100  IP  address,   right now eth0 is working fine but eth1 giving error on loading of client (see the attached picture) I want to access both networks . like in DCE we can access both LAN in same time. is there any option to access same like that.
(CID:105459078)
  • Data Center Operation
Hi Ali,
Unfortunately that is not a supported configuration, currently it is not supported to configure two network interface (in DCO). I think we have recently registered a similar feature request. If you could kindly email me your company name, then I will add it to the existing case, thanks.
Kind regards
(CID:105459094)
Hi Ali,
Kind regards
(CID:105459094)
Posted: ‎2020-07-02 09:41 PM . Last Modified: ‎2023-10-31 11:03 PM
