How to IP/Configure and add device Netbotz 455
  • How to IP/Configure and add device Netbotz 455
126
65
Posted: ‎2020-07-04 08:20 PM . Last Modified: ‎2024-04-04 04:14 AM
1002
(CID:132665962)
  • NetBotz
Replies 5
Hi Zeke,
You can reference the link below on how to configure an IP on a Netbotz appliance.
http://www.apc.com/ph/en/faqs/FA308010/
Can you confirm what devices you are planning to add/configure on the Netbotz?
John
(CID:132666027)
1002
John,
Thank you very much for your answer and reference link. It was helpful info. To answer your question. We are using Flood, Temp, and Humidity sensors on the Netbotz 455. Sorry for the delay response.
Zeke
(CID:132668460)
Hi Zeke,
If you are referring the Flood sensor as the Leak Rope sensor, it is not compatible with the Netbotz 455 (Room monitor).  Below link is the compatibility matrix for Netbotz.
http://www.apc.com/salestools/JHIN-7PTK7P/JHIN-7PTK7P_R7_EN.pdf
Hope this helps.
Kind regards,
John
(CID:132668688)
Thank you, for the heads up! I was not aware of that.
(CID:132669555)
Posted: ‎2020-07-04 08:21 PM . Last Modified: ‎2023-10-22 02:24 AM
