Posted: 2020-07-04 06:06 PM . Last Modified: 2024-04-04 11:42 PM
Hi Team, may I ask how I can make the Serial Number appear on the column of the generated report on DCO?
The report column has: Name, Location, Bar Code, Part Number and Description Column.
Can I change the Barcode or Part Number into Serial Number Column?
Thank you.
(CID:131964859)
Hi Dondee,
No, that's not supported, the layout of the standard reports cannot be changed.
But it should be possible to create customized reports (requires some developer skills) using Insight (StruxureWare Data Center Operation: Insight) or other tools.
As a current work around, you might want to use Equipment Browser (Working with the Equipment Browser) and exporting the data/table into a text file.
Kind regards
(CID:131964877)
Hi Dondee,
Kind regards
(CID:131964877)
Posted: 2020-07-04 06:06 PM . Last Modified: 2023-10-22 02:24 AM
