Posted: 2020-07-03 03:20 PM . Last Modified: 2024-04-08 01:00 AM
I want to change label of a device but I counld't find it in Data Center Expert.
I also couldn't find it directly from device by connecting its IP adress from web browser.
Devices are Servertech(CS-30VEKD25D8) and Raritan(PX2-1493) PDU.
As you can see, some of servertech devices' label are changed.
Any suggestions?
(CID:116922008)
Erhyan,
You can update (change) the device label by editing the SNMP settings within the devices via its web browser interface IE for the Raritan devices it is found under "Device Settings" then "Network Services" then "SNMP" there you will find you can set the sysContact, sysName & sysLocation. The sysName is the "label"
I would assume the Servertech devices will be basically the same but since I do not have any I can give you the exact path to find where you can edit the SNMP settings.
Best regards
Mike.
(CID:116922020)
Erhyan,
Best regards
Mike.
(CID:116922020)
Hello Mike,
Thanks for the response. It worked.
Best regards,
Erhan
(CID:116922348)
Your most welcome and glad to help!
(CID:116922367)
Posted: 2020-07-03 03:20 PM . Last Modified: 2023-10-22 02:24 AM
