Posted: 2020-07-05 01:43 PM . Last Modified: 2024-04-04 12:24 AM
If you have a sensor that starts having issues - it will sometimes give out incorrect readings, wildly high, or wildly low. Or, just drop completely.
This data can be determined to be anomalous fairly easily.
However - it remains in the historical data base.
How do I remove that specific, easily identifiable data ? We don't need garbage in our historical data long term.
See the light blue line in the graph below :
(CID:134693859)
Posted: 2020-07-05 01:44 PM . Last Modified: 2024-04-04 12:24 AM
Hi Eric,
You can un-check this sensor from 71 sensors shown in your report and that will not show readings from that particular sensor.
I don't think you can isolate this sensor and delete it from DCE database.
But you can certainly remove from DCE so this sensor will not be shown.
So there are 2 methods either un-check or delete form DCE at-least that's what I know.
Regards
Chaitanya
(CID:137107816)
Posted: 2020-07-05 01:44 PM . Last Modified: 2023-10-22 02:22 AM
