Posted: 2020-07-04 02:56 AM . Last Modified: 2024-04-05 03:40 AM
How do i intergrate two alerts ( Power Loss and Temp Changes ) into struxureware from a monitoring tool called VROPs
(CID:126880914)
Hi Carmine
Are you referring to SXW DCE, DCO or some other product?
Cheers
Ed
(CID:126886073)
Hi Carmine,
In DCO, the possible alarms/notifications can be received from the integrated external system(s) (such as DCE). Out of the box, it is not supported to integrate VROPs as an external system in DCO, however an integration through ETL (customized work) might give you some possibilities (to bring the alarms into DCO). More info available here: ETL - Extract Transform Load
Kind regards
(CID:126881290)
Posted: 2020-07-04 02:56 AM . Last Modified: 2023-10-22 02:22 AM
