How do i intergrate two alerts ( Power Loss and Temp Changes ) into st
EcoStruxure IT Forum
  • Re: How do i intergrate two alerts ( Power Loss and Temp Changes ) into st
Cory_McDonald
Admiral Cory_McDonald Admiral
127
Jef
Admiral Jef Admiral
111
gsterling
Captain gsterling Captain
71
Back to EcoStruxure IT Forum
DCIM_Support
Picard DCIM_Support
Picard
Posted: ‎2020-07-04 02:56 AM . Last Modified: ‎2024-04-05 03:40 AM
746
How do i intergrate two alerts ( Power Loss and Temp Changes ) into struxureware from a monitoring tool called VROPs
(CID:126880914)
  • Data Center Operation
Replies 3
DCIM_Support
Picard DCIM_Support
Picard
Hi Carmine
Are you referring to SXW DCE, DCO or some other product?
Cheers
Ed
(CID:126886073)
DCIM_Support
Picard DCIM_Support
Picard
Hi Carmine,
In DCO, the possible alarms/notifications can be received from the integrated external system(s) (such as DCE). Out of the box, it is not supported to integrate VROPs as an external system in DCO, however an integration through ETL (customized work) might give you some possibilities (to bring the alarms into DCO). More info available here:  ETL - Extract Transform Load
Kind regards
(CID:126881290)
DCIM_Support
Picard DCIM_Support
Picard
Posted: ‎2020-07-04 02:56 AM . Last Modified: ‎2023-10-22 02:22 AM
