How do I use the mapping tab
  • How do I use the mapping tab
129
72
Posted: ‎2020-07-05 10:45 PM . Last Modified: ‎2024-04-03 12:21 AM
1311
(CID:149785277)
1311
Hi John,
I'm assuming you're referring to the "Map View" tab on the monitoring perspective.
Simply right click on an empty space or even a device and choose "Edit Map":
You can then again right click and choose things like auto-arrange or you can move things around manually. If you select map settings, you can select different identifiers to show next to the icon representing the different devices:
You can then change the map background, make small or large icons, etc as shown here:
When you're finished, choose "Save Map" and / or exit edit map from the right click menu.
If you go to Help–>Search Help, searching Map View will tell you the different options you have and walk you through much of it.
Steve
(CID:149785287)
Replies 5
1312
Hi John,
Steve
(CID:149785287)
Thank you, are you able to use Google maps
(CID:149785293)
Hi John,
You can add an image. If you take a screenshot of a google maps map, you can then add it as a custom background. You can not however configure the map view to connect to an external system such as google maps.
Steve
(CID:149785296)
Thank you for getting back with me so quickly. I have done just what you said and it works beautifully.
(CID:149785298)
Posted: ‎2020-07-05 10:46 PM . Last Modified: ‎2023-10-22 02:21 AM
