Share Your Feedback โ€“ Help Us Improve Search on Community!
How do I upload a new SSL cert (not self signed) to a PDU?
Showing results forย
Did you mean:ย
  • How do I upload a new SSL cert (not self signed) to a PDU?
129
72
Posted: โ€Ž2020-07-05 06:12 PM . Last Modified: โ€Ž2024-04-03 03:05 AM
3148
I need to upload a new SSL cert to the PDU's (AP8941 and AP7911B) so they are not using a self signed cert.  Do I need to generate a CSR on the PDU and if so, how do I do this?
(CID:141265077)
  • IT Expert
3144
Hi Krista!
You can generate CSR using APC Security Wizard software.
It's available on apc.com web site/
https://www.apc.com/shop/my/en/products/APC-Network-Management-Card-Security-Wizard-v1-0-4/P-SFNMCSE...
(CID:141265129)
Replies 5
3145
Hi Krista!
(CID:141265129)
Thanks for the link.  I generated the CSR and also had a cert created but the software seems to hang at about 50% when I try to import it in the wizard.  Have you ever seen that before?
(CID:141265202)
No, I'm not ๐Ÿ˜ž
(CID:141265375)
I'm still troubleshooting the issue but appreciate the help in getting to this point.
(CID:141267244)
Posted: โ€Ž2020-07-05 06:12 PM . Last Modified: โ€Ž2023-10-22 02:21 AM
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
