Posted: 2020-07-05 08:25 PM . Last Modified: 2024-04-03 01:13 AM
Hi ,
How do I move only surveillance license packs from a DCE virtual appliance to another DCE virtual one?
(CID:146278219)
Hi Shaik,
Good day!
It is best to contact your local technical support for that request. Before contacting technical support, it is best to verify and confirm the following:
This is for us to pull up your account and work on your request to move the surveillance license.
I hope this helps.
Justine
(CID:146278234)
Just a side note, the single surveillance license that comes by default with the server is not transferable.
(CID:146669780)
Posted: 2020-07-05 08:25 PM . Last Modified: 2023-10-22 02:21 AM
