Access DCE virtual machine via VMware-console
  • EcoStruxure IT forum
  • Access DCE virtual machine via VMware-console
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 08:24 PM . Last Modified: ‎2024-04-03 01:14 AM
1142
Is it possible to verify/change network settings on DCE virtual machine via the VMware-console. The splash screen for the DCE virtual machine console warns that system login without direction from Schneider Electric support will void warranty.  Virtual DCE server will not ping following Network settings change although VM server is powered up and console is responding with logon.
(CID:146278102)
Posted: ‎2020-07-05 08:24 PM . Last Modified: ‎2024-04-03 01:13 AM
1142
Hello Barry,
Via the console you can you log using apcinfo/apcinfo to view the current network settings.  If something needs to be changed, you can log in using apcsetup/apcsetup (defaults, unless otherwise changed).
Video: Data Center Expert | How do I configure the network settings?
https://www.apc.com/us/en/faqs/FA234266/
Data Center Expert | What are the default credentials?
https://www.apc.com/us/en/faqs/FA316534/
Kind Regards,
Cory
(CID:146278114)
Replies 5
1143
Hello Barry,
Kind Regards,
Cory
(CID:146278114)
Hi Cory, thanks for the quick response. Will logging into the DCE console using apcinfo/apcinfo or apcsetup/apcsetup void the warranty.
(CID:146278133)
Posted: ‎2020-07-05 08:25 PM . Last Modified: ‎2024-04-03 01:13 AM
Hi Barry,
Logging in with those accounts (apcinfo & apcsetup) will not void a warranty.  There are limited actions that can be taken within them just to view network settings or change network settings.
Kind Regards,
Cory
(CID:146278135)
Thanks again Cory, I appreciate you help and expertise.
(CID:146278202)
Posted: ‎2020-07-05 08:25 PM . Last Modified: ‎2023-10-20 04:58 AM
