How do I change NetBotz temperature readings to degrees celsius
  • EcoStruxure IT forum
  • How do I change NetBotz temperature readings to degrees celsius
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 07:21 AM . Last Modified: ‎2024-04-10 01:43 AM
3376
Dear Team,
How do I change the NetBotz temperature reading from fahrenheit to degrees celsius on the browser and email alerts of NetBotz Rack Monitor 450. I have unsuccessfully tried to change the locales on the NetBotz.
Felix Angwenyi
(CID:87589099)
  • NetBotz
Hi Felix,
What is shown in e-mails from the NetBotz appliance is based on the NetBotz regional settings. The scale which is shown in either the basic view (web) or advanced view software is based upon your local computer's regional settings.  You will need to change the Region icon in Advanced View to reflect your region. You will also need to ensure that the correct time zone is selected on the PC that is running Advanced View and also the correct regional settings is configured on the PC running Advanced View.
Hope this helps.
B
(CID:87589103)
Replies 11
Hi Felix,
Hope this helps.
B
(CID:87589103)
3377
HI,
We recently upgraded our NetBotz 450 to 4.5.2 (Build: 20160602_1247) and now there is no way to change temperature readings to Celsius (email, sms, and web). No matter what the Regional settings are on the workstation, NetBotz always use Fahrenheit degrees.
Is there a way to change that?
(CID:106207931)
Hi, Kindly check if you've changed the NetBotz locale using the Configuration wizard or on the configuration pane to United Kingdom or your own locale that's if you use the metric system. Regards, Felix.
(CID:106207936)
Posted: ‎2020-07-02 07:21 AM . Last Modified: ‎2024-04-10 01:42 AM
Thanks, Felix. Regional settings are OK in both NetBotz and workstation. After a restart, we managed to have Celsius in SMS and emails. But we still didn't in web and Advance View app.
(CID:106207940)
Same issue here.
(CID:106210277)
I met the same issue in China and privious version is 4.5.0, display as C, but after upgrade to 4.5.2, it displays as F, and both the region of Netbotz and PC are not changed, both are China UTC +8.
(CID:106891435)
Same issue here. How to back Celsius?
(CID:109446926)
Posted: ‎2020-07-02 07:22 AM . Last Modified: ‎2024-04-10 01:42 AM
Same issue: I am running Version 4.5.2 (Build: AV_20160602_1403) and can not display temp in Celsius on advanced view app.
(CID:110005462)
Same issue here, one 570, one 550 and one 450, and for NONE we can change from F to Celsius...
(CID:118004098)
Are you guys suggesting that we downgrade our version to an earlier one ? 4.5.1 ?
(CID:123341002)
Posted: ‎2020-07-02 07:22 AM . Last Modified: ‎2023-10-31 11:02 PM
This is a heading
