How do I add DCO in to DCE?
Showing results forΒ
Did you mean:Β
  • How do I add DCO in to DCE?
126
65
Posted: β€Ž2020-07-05 10:20 PM . Last Modified: β€Ž2024-04-03 12:30 AM
1347
Afternoon,
Today i have had to rebuild my DCO server with 8.2.3, How do i add the DCO server back in to DCE? reason for asking is because the IP address and host name have now changed, old server will be removed, but before removing it I want to make sure i am able to add it back in.
Martin
(CID:149291588)
  • Data Center Operation
Replies 9
Posted: β€Ž2020-07-05 10:21 PM . Last Modified: β€Ž2024-04-03 12:30 AM
1347
Dear Martin Parks,
You need to rediscover the DCO-server as an SNMP device at the new IP address. Please, make sure that the latest version of the schneiderops.xml v.5 DDF-file is installed on the DCE-server.
With respect.
(CID:149291631)
Thank you for you reply,
How do i ensure the schneiderops.xml v.5 DDF file is installed? This server has just been upgraded to the latest version of 7.7.1.
Also, can there only be 1 DCO server added to DCE at any one time? i.e. i cant add the new server till the old one is removed?
(CID:149291823)
Dear Martin Parks,
From your question:
In the DCE-client, this can be found from the menu Device -> SNMP Device Communication Settings -> Device Definition Files:
The latest schneiderops.xml DDF-file can be downloaded from the web resource, from where you downloaded the iso-image of the DCO-server.
You can add as many DCO-servers as you need (of course, taking into account restrictions on the number of nodes in DCE).
With respect.
(CID:149291866)
Do you have a link to some instructions on adding DCO in to DCE?
I have just updated the definition file so it is now V5, and ran a discovery to the new IP for DCO server, however the discovery doesn't appear to run and the new server is not displayed
(CID:149291905)
I have now been able to add the device in to DCE using SNMP v1, is there a way of setting it up so it uses SNMP v3?
(CID:149291908)
Dear Martin Parks,
From your question:
Unfortunately, I do not know about the existence of such an instruction.
I think you need to make the appropriate settings on the side of your new DCO-server. I draw your attention to your last question  and to the answer:
With respect.
(CID:149291934)
Thank you very much, I totally forgot I asked that question a long time ago πŸ˜‚
(CID:149291956)
Just searching helps πŸ˜‰
(CID:149291961)
Posted: β€Ž2020-07-05 10:21 PM . Last Modified: β€Ž2023-10-22 02:20 AM
