How can we change mass snmp device password
  • How can we change mass snmp device password
127
65
Posted: ‎2020-07-04 02:50 PM . Last Modified: ‎2024-04-05 02:31 AM
992
Can any one provide me the procedure to change snmp mass device password push.
Can it be done by creating template ? Retrieving setting from selected device from Device configuration Access
(CID:129403749)
Replies 5
Dear Shaik Mahboob Ali,
Please specify what do you mean by the phrase "...snmp device password"? This is SNMPv3 pass phrase or password for web-GUI or CLI devices, for example?
With respect.
(CID:129404018)
Posted: ‎2020-07-04 02:50 PM . Last Modified: ‎2024-04-05 02:30 AM
I need to change passwords in all snmpv1 devices in one short so how can we push password for all my snmp v1 devices. I check with APC SNMP devices configuration but it only change to only 6.0 and higher version .
With Standard device configuration i cannot. Is there any method to change password at once for all SNMPv1 devices.
(CID:129405303)
992
And nevertheless for me it normally works. For example, in DCE-7.5.0 in the Configuration Type window, I select the Standard device configuration settings option, since I have old (Gen1) and new (Gen2) devices:
Then for older (Gen1) devices, after they have been selected, you can change the Administrator Password parameter in bulk as in my screenshots:
and...
Likewise, for new (Gen2) devices, once they are selected, you can change the Administrator Password parameter in bulk as in my screenshots:
and...
I hope this helps you.
With respect.
(CID:129405481)
Posted: ‎2020-07-04 02:51 PM . Last Modified: ‎2024-04-05 02:30 AM
Hi ,
I have done above steps but still you can see the below snap short error message " Incomplete Configuration" and i cant change the pwd.
(CID:129405542)
Posted: ‎2020-07-04 02:51 PM . Last Modified: ‎2023-10-22 02:19 AM
