Posted: 2020-07-02 09:12 AM . Last Modified: 2024-04-10 01:17 AM
(CID:92539605)
Hi Felix,
You will need to first use Netbotz devices (e.g NBRK0570, NBRK0201) and dry contact sensors(NBES0304) to monitor all your dry contact devices.
If you need to monitor a lot of dry contact devices(e.g 50+ dry contact points), you may want to consider using Netbotz and Sealevel I/Os.
Have DCE to monitor those netbotz device(s).
Hope this helped.
(CID:92539617)
Posted: 2020-07-02 09:12 AM . Last Modified: 2023-10-31 11:00 PM
