How can I generate a report of all single power equipment?
  • How can I generate a report of all single power equipment?
129
72
Posted: ‎2020-07-04 07:16 PM . Last Modified: ‎2024-04-04 11:16 PM
872
(CID:132654556)
  • Data Center Operation
Hi Rose
Assuming you're talking about DCO....
I was hoping the "Power Inlets" value was visible in the equipment browser but it appears not.  I recommend adding a Feature Request
There are many other ways to get your report
  1. DCO Report using  StruxureWare Insight
  2. ETL Export and then use your corporate / favourite report writer although I couldn't find the inlet in the ETL Export DB Schema
  3. API
    1. curl -X GET --header 'Accept: application/json' 'https:///api/v8.1/assets/'
      This could then be scripted into a email and run at regular intervals via cron
Let me know if you'd like some more assistance
Cheers
Ed
(CID:132654583)
Hi Rose
  3. API
Cheers
Ed
(CID:132654583)
Posted: ‎2020-07-04 07:16 PM . Last Modified: ‎2023-10-22 02:18 AM
