How To Model In Rack Rectifier
  • EcoStruxure IT forum
  • How To Model In Rack Rectifier
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 01:26 PM . Last Modified: ‎2024-04-08 01:37 AM
1047
What is the best way to model an in rack rectifier.  I have two similar situations
In both cases there is some DC powered kit in a rack, this is powered by an in rack rectifier.  One situation is the rectifier is connect to in rack AC power strips and the other is the rectifier is connected to an AC breaker.
(CID:113641154)
  • Data Center Operation
Replies 4
1047
If you want to show it in power path and have its load calculations taken into account, you can model the rectifier as an IT device that gets power from the rack pdu or off of a power panel.
If you are trying to model the DC power path and the devices it powers, thats a different story.
 However as of right now, there are some limitation in what you can do with DC power path.  it follows all of the same rules as a floor UPS:
  1. it cannot have an AC source, it is the highest point in the power path
  2. it cannot be mounted in a rack, it has to be a floor device
  3. it cannot have DC distribution, you need to create a separate DC floor pdu
  4. it can't feed device directly, you have to have a DC pdu which then feeds DC rack pdus
  5. if it is dual fed, dual output for A/B sources, you need to make 2 devices, one for A feed, one for B feed.  This also applies to in rack dc fuse panels, you need to make 2 shelf mount devices that are half the size.
(CID:113641300)
Andrew Trabert - So at the moment DCO can't accurately model the situation, can this be caputred as a feature request?
Would you be able to advise what the best model is in DCO for the following;
Switch A is powered from Power Unit A & B.  Power Unit A is fed from the Orange in rack power strip and Power Unit B from the Grey.  The two in rack power strips are connect to a breaker on a power panel.
At the moment it is showing 4 power connections in the rack (giving it double the capacity)
Also there seems to be an error whereas there is 0kW capacity for each unit, even thought the power strips are connected
It's also not showing live readings, but I feel that is a seperate issue
(CID:113641529)
correct, its not a 1:1 representation, but it can still be modeled, albeit a little convoluted.
you can't model a rack pdu feeding a rack pdu or rack mount ATS ( DCO also does not support dual fed rack ATS').  You also can't power a device from a different rack.
Model Power unit A/B as generic rack mount equipment, then increase the outlet count in the zero U rack mount power strips so that they equal the number of outlets in both the rack mount power strip and the horizontal power strip -1.  Then connect Switch A to the zero U rack mount power strips.
From a power path/capacity perspective, Daisy chaining rack pdus just adds outlets, not power capacity, so this work around still accounts for that.  The only thing it doesn't do is include the horizontal power strips in impact analysis.
(CID:113641727)
Posted: ‎2020-07-03 01:26 PM . Last Modified: ‎2023-10-22 02:17 AM
