How DCO extends the partition
  • How DCO extends the partition
129
72
Posted: ‎2020-07-04 05:01 PM . Last Modified: ‎2024-04-05 12:03 AM
1422
(CID:130680791)
  • Data Center Operation
Hi xpower123,
DCO dose not offer built in option to extend partitions - to have a reliable system I would suggest:
a) backup the current setup
b) make a clean installation (check the system recommendations describe here System requirements), use your largest disk for installation (eg. your 500 GB disk)
c) and then restore the backup (from a).
Kind regards
(CID:130683600)
Replies 5
Hi xpower123,
Thanks for posting! Can you add a little more detail to your question?
Best regards,
Stine
(CID:130681741)
(CID:130681887)
How to expand the system partition, DCO do a good job of the partition, there are new disks, how to expand the space of the new disk to the existing partition? As shown, the display file system is less than 20G, but the disk shows 560G of space.
(CID:130683299)
Hi xpower123,
Kind regards
(CID:130683600)
Posted: ‎2020-07-04 05:01 PM . Last Modified: ‎2023-10-22 02:17 AM
