Posted: 2020-07-03 04:40 PM . Last Modified: 2024-04-08 12:29 AM
Hi I am unable to see Hostname column in any reports.I have already updated DNS records even though i cannot see the hostname column.
Any way to get this Host Name in reports to identify devices.
(CID:120130112)
Hi Shaik,
Although hostname is an option when initially configuring the report:
I am assuming when selecting sensors and devices, you can see hostname, correct? I can:
I can see that hostname is not an option in the report itself or when editing report options:
I can put in an enhancement request for this but there's little we can do right now other than using the custom properties option. You can see above that my custom "Asset Tag" properties are available.
If you're referring to something else that I may have missed, please specify.
Steve
(CID:120130177)
Hi Steve,
You are right " host-name is not an option in the report itself or when editing report options:" so need to put in an enhancement request. This will be very helpful.
(CID:120131249)
Posted: 2020-07-03 04:41 PM . Last Modified: 2024-04-08 12:29 AM
Hi Shaik,
I put a request in to the system yesterday. Can't say when it may make it into the system though.
Steve
(CID:120131247)
Posted: 2020-07-03 04:41 PM . Last Modified: 2023-10-22 02:17 AM
