Has the list of Pelco Cameras been updated
  • Has the list of Pelco Cameras been updated
127
Posted: ‎2020-07-04 09:16 PM . Last Modified: ‎2024-04-04 03:49 AM
1390
Does anyone know if the list of compatible Pelco cameras been updated as most of these have been replaced!
TIA
Mike
(CID:133367901)
  • NetBotz
Posted: ‎2020-07-04 09:17 PM . Last Modified: ‎2024-04-04 03:49 AM
1390
Hi Mike,
The list of Pelco cameras can be seen in the article from the link below:
http://www.apc.com/ph/en/faqs/index?page=content&id=FA158450
The article lists Pelco cameras that are also compatible with BotzWare version 4.X and also mentions that NetBotz can no longer support Sarix Pro models because they do not correctly update the resolution settings presented to NetBotz appliances.
IJP121-1IS is known to have communications issues with NetBotz, and until these issues are resolved, the IJP121-1IS should not be considered compatible with NetBotz.
If the camera that you are interested in checking is not listed, please let me know so I can check with the quality team for a final answer.
Justine Chester
(CID:133367930)
Replies 8
1391
Hi Mike,
Justine Chester
(CID:133367930)
Hi Justine,
Kindly any pelco dome day/night camera that NetBotz supports?
Felix.
(CID:133369091)
Hi Felix,
Good day!
IMSOC10 and SD4N-W0 are both dome type IP cameras, as per Pelco's website.
The link that I shared above has the updated list of Pelco cameras that are supported by Netbotz v3 which includes their respective model numbers. The model numbers from the link can be used on Pelco's website to get more information regarding these cameras (including their appearance and type).
Kind regards,
Justine Chester
(CID:133369191)
Hi Justine,
I have a customer who needs a night vision camera compatible with the NetBotz 570,
I have checked with Pelco and they say IXE20DN and IX30DN have been discontinued, kindly are their replacement compatible?
Thank you.
Felix
(CID:133369342)
Hi Justine,
Please see below communication from the Pelco distributors.
Please find the below Pelco part numbers which are replacement of the requested models.
Replacement  model for IXE20DN is.
IXE22
SRX ENH+ BOX POE1224V 2MP
Replacement model of IX30DN is.
IXE32
SRX ENH+ BOX POE1224V 3MP
(CID:133369356)
1390
Hi Justine,
Thanks the IME119 has been discontinued and replaced with the IME229 do you have info on this model.
Cheers,
Mike
(CID:133371617)
Hi Mike,
As of now, only the listed models on the article that I have shared are compatible with our Netbotz v3.
I have already raised this query with my colleagues and hopefully we will receive an update regarding this.
Justine Chester
(CID:133372018)
Posted: ‎2020-07-04 09:17 PM . Last Modified: ‎2023-10-22 02:15 AM
