Global Capacity Overview
  • EcoStruxure IT forum
  • Global Capacity Overview
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:29 PM . Last Modified: ‎2024-04-09 01:26 AM
581
Hi All,
I have a few question about capacity;
How global overview is calculated? I shared an image below, as that cooling is seems 1527%, so how can this possible?
Additionaly, my realtime power value is 264 kw, but it seems 277 kw, so how should i do for change it?
Secondly, there is two ups is associated with DCE but one ups value seems correct but the other one is wrong, lthough i check every points for calculating.
Regards
Kerem
(CID:105460715)
  • Data Center Operation
Posted: ‎2020-07-02 10:30 PM . Last Modified: ‎2024-04-09 01:26 AM
Hi kerem.yilmaz
It is hard to say exactly why the numbers are like this without knowing the setup.
For the Cooling it might be that you have very little IT equipment in the racks which might cause it to act a little strange.
Is this data center fully modelled with server and everything? Maybe you can share the solution with us. This will make it easier to investigate.
For the UPS that shows wrong value in DCE. Do you mind creating a new case on EcoStruxure IT Help Center since they might not be related. We would like to keep one question per EcoStruxure IT Help Center case. This will make it easier to search afterwards.
Below is the information about the Capacity overview
Capacity overview
If you have a valid StruxureWare Data Center Operation: Capacity license, the information boxes also show a capacity overview represented as a pie chart. It sums up the status of power, cooling, space, and network of the selected location or room.
Power is represented as the percentage of the available load (kW) that is utilized by the IT equipment in the location or room.
Cooling is represented as the percentage of the available load (kW) that is utilized by the IT equipment in the location or room.
U-space is represented as the percentage of the available U-positions (U-pos) that is populated with equipment in the location or room.
Network is represented as the percentage of the available Network ports (ports) that is utilized by networking equipment in the location or room.
Jesper
(CID:105460906)
Hi kerem.yilmaz
Capacity overview
Jesper
(CID:105460906)
Posted: ‎2020-07-02 10:30 PM . Last Modified: ‎2023-10-31 11:00 PM
