Getting PUE from DCO into Portal
  • EcoStruxure IT forum
  • Getting PUE from DCO into Portal
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:33 PM . Last Modified: ‎2024-04-05 12:31 AM
731
I am having an issue with getting the PUE value from DCO to work in portal. I have added an iFrame portlet and directed it to the appropriate webpage as was mentioned in another post but I am left with the following message:
Both of my VMs (DCO and the VM with portal) are on the same network with no firewall and have no issues communicating using other portlets. What could be causing the disconnect? Here is the setting I used to setup the iFrame:
It is to note that this is the non Energy Efficiency version of the PUE which I would use the specified DCO portlet for.
(CID:129409810)
  • Data Center Operation
  • Portal
Posted: ‎2020-07-04 03:34 PM . Last Modified: ‎2024-04-05 12:31 AM
Only the PUE from the Energy Efficiency option can be integrated in Portal.
(CID:129409861)
Hi Neil,
Sorry to disappoint, as you might have noticed already we do not have a supported portlet for the so-called simple PUE. And I do recall that for security seasons, iFrame had been prevented from DCO side some years ago.
Kind regards
(CID:129409866)
Posted: ‎2020-07-04 03:34 PM . Last Modified: ‎2023-10-22 02:09 AM
