Get more info than what is reported on PDUs
  • EcoStruxure IT forum
  • Get more info than what is reported on PDUs
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:07 AM . Last Modified: ‎2024-04-10 12:40 AM
738
Ia there a way to extract/calculate in DCIM Expert  more data than I am recieving from a PDU?  Example, of a Panduit PViQ PVQ6.  I get amps per circuit, but can I calculate/report to KW/KVA??
(CID:94602656)
738
Hey Ryan,
Good afternoon, the PDUs you are referring to are rack based powerstrips monitored via SNMP correct?  If the device offers more data points than you are currently picking up then it may be possible to update the DDF for these devices (contact multivendorsupport@schneider-electric.com and they will require a SNMP walk of the device, MIB file, and a form to complete).
If the devices doesn't offer any more detailed data, the only calculations that DCE can provide are averages or totals of like sensor values.  Hope this helps
(CID:94602660)
Posted: ‎2020-07-02 11:08 AM . Last Modified: ‎2024-04-10 12:39 AM
Hi there, please assist
I have RPDU AP8953, my client has requested a report to determine power consumption per outlet of connected devices - i.e. server/switch/blades etc.
I am aware that DCO ITO has this functionality, however we do not have this available, any ideas\advise how I would be able to accomplish this task?
Would upgrading the firmware of the PDU allow this functionality?
Currently my workaround is calculating the amount of connected devices to the PDU divided by the total consumption of the PDU,
pLEASE advise
Any help, recommendations and suggestion is greatly appreciated.
Regards
(CID:126159170)
Posted: ‎2020-07-02 11:08 AM . Last Modified: ‎2023-10-31 10:59 PM
