Genomes : DCO
  • EcoStruxure IT forum
  • Genomes : DCO
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-06 01:21 AM . Last Modified: ‎2024-04-02 11:15 PM
2599
Genomes : DCO
How to update Genomes with latest and how to check the Current version.
Please advise.
with regards,
Noushad Abdussalam.
(CID:154405172)
  • Data Center Operation
  • Genome
Replies 4
2598
Hi Noushad,
What is the version of your DCO?
If you go to (via desktop client) Tools > Preferences > Genome Library, you may see your latest update.
For more info on manual see the following page, which also contains a link to Genome Library download page: https://sxwhelpcenter.ecostruxureit.com/display/download/Genome+Library (may require that you have community login access).
However, for the time being updates after November 2019 are included in the latest DCO/ITA released versions, so if you have a latest version of DCO/ITA then your Genomes should be updated already.
Kind regards
(CID:154405184)
Hi Jef,
Thanks for you reply, I'm using DCO version 8.3.2.
My Current genome library generated : 5/1/19 PM.
(CID:154405235)
Posted: ‎2020-07-06 01:22 AM . Last Modified: ‎2024-04-02 11:15 PM
Hi Noushad,
Then download and apply the latest update file (at the moment it should be called Genome_112029.zip), to see/get the download link go to the above mentioned Genome Library page. After a successful update we may see this:
Kind regards
(CID:154796070)
Posted: ‎2020-07-06 01:22 AM . Last Modified: ‎2023-10-22 02:09 AM
