Posted: 2020-07-05 10:39 PM . Last Modified: 2024-04-03 12:24 AM
Can I get the information from the devices into ITA cloud only having the IT-gateways (without IT Expert)?
(CID:149783414)
Posted: 2020-07-05 10:39 PM . Last Modified: 2024-04-03 12:23 AM
Hi Eduard,
No you cannot, ITA (cloud) can get the data from the integrated ITE and not directly from a gateway.
Kind regards
(CID:149783445)
Hi Eduard,
Kind regards
(CID:149783445)
Hi Jef,
What do you mean with integrated ITE?
- integrated in what?
(CID:149784025)
Hi Eduard,
ITA (cloud) can only get data from ITE and not directly from a gateway.
Kind regards
(CID:149784038)
Hi Jef,
So at this customer we will need DCE (including Gateway) and Gateway NUC+ITA in parallel monitoring the same devices. How will IT Asset advisor react when it sees most of the devices twice?
(CID:149784631)
Hi Eduard,
The discovery of the devices (send to cloud) they are based on unified ID, and not tied to DCE or Gateway, so not expecting to see the devices twice.
Kind regards
(CID:149784641)
Posted: 2020-07-05 10:40 PM . Last Modified: 2024-04-03 12:23 AM
Hi Jef,
I will set it up in the coming month and give you the feedback.
(CID:149785072)
Posted: 2020-07-05 10:40 PM . Last Modified: 2023-10-22 02:06 AM
