GSM modem connectivity issue with 570
  • GSM modem connectivity issue with 570
129
72
Posted: ‎2020-07-05 07:43 PM . Last Modified: ‎2024-04-03 02:33 AM
1135
I have installed a GSM gateway of multi tech (model no # MTCBA-G2-U). Which is connected with rack monitor 570. I am facing an issue during its configuration. Please check the setting of this modem. If any thing is wrong please share the correct setting.
I have attached the snapshot for your kind reference.
(CID:144312267)
  • NetBotz
Replies 4
Hi Shoaib Maqsood, thanks for posting!
If this issue still persists I suggest you call your local tech support for guidance.
Stine
(CID:144868375)
HI Shoaib
We are using the GSM modem to send sms. We had the same issue - losing connectivity to the modem.
We identified the issue to a faulty modem. When we connected the multi-tech modem, we selected the correct (multi-tech Multimodem GPRS) model using the Serial Devices Icon. Afterwards, we verified the configs under all tabs - ( Basic, Advanced and Status) of SMS icon.
Note, Status tab displays the signal strength to your ISP, a good signal is important.
I hope this helps
Kind regards
(CID:145851187)
Please check the attached screen shots.
Current Setting of the GSM gateway. kindly check and suggest us. What is the role of Sim Pin?
(CID:147198186)
Posted: ‎2020-07-05 07:43 PM . Last Modified: ‎2023-10-22 02:06 AM
