Full alarm synchronization from DCE by DCO
  • EcoStruxure IT forum
  • Full alarm synchronization from DCE by DCO
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 04:42 PM . Last Modified: ‎2024-04-09 02:42 AM
586
Can we get DCE alarm shown in DCO faster? From setting, looks like we are limited to 5 minutes polling interval. (Full Alarm synchronization time)
Thank you.
(CID:103585776)
  • Data Center Operation
Replies 4
586
Hello Ling,
Generally speaking the time frame from my testing is approximately 30 secs from when DCE gets an alarm to DCO seeing the alarm. A few things that I would recommend checking
  1. Device that is going into alarm is associated to a asset in DCO.
  2. The alarm is not for lost communication, an actual alarm on the device itself
  3. Reduce the time option for "Update Device information" to less then 300 seconds. This might impact DCE performance slightly so keep that in mind when reducing this setting.
As well as, DCO relies on the network for HTTP/HTTPS requests. If there is alot of traffic on the network we may see slow response to new or clearing alarms.
Victor
(CID:103585830)
"Update Device information" does not influence how quick alarms are send. Reducing it is not a good idea.
(CID:103585844)
The DCE will push new alarms to DCO more or less immediately after it receives an alarm. The DCO will on a regular interval load all alarms from DCE to guard against communication lost etc. in the push. The latter is the Full Alarm synchronization time.
So unless there's network communication issues, "Full Alarm synchronization time" does not influence how quick new alarms are received in DCO.
(CID:103585843)
Posted: ‎2020-07-02 04:42 PM . Last Modified: ‎2023-10-31 10:59 PM
