Floor level view vs. room view
  • EcoStruxure IT forum
  • Floor level view vs. room view
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 12:59 AM . Last Modified: ‎2024-04-05 04:18 AM
773
Hello. I have noticed that Floor layout view does not anymore correspond the room layout that is actually in the room.
Here is my "Floor layout" when only Floor tab is opened. There are some old racks placed in the room. I think this was room layout long time ago when it was initially modeled in the tool:
If I open that particular room and I go back to Floor tab (while room tab is also opened), I see the current room layout that is correct:
Again, if I close room tab, the floor layout shows the old placement of the rack in the room:
Is there a way to update room layouts in the floor tab somehow?
In addition, if I move room walls, they are shown only when the room is opened as a tab. Otherwise the room shape is like it used to be before modification in the floor layout.
(CID:126166651)
  • Data Center Operation
Hi Jarno,
This is reproducible, it seems currently the 'floor layout' is not being updated. I have logged this as a software bug, so it could be fixed in a future version. Many thanks for reporting.
As a sort of work-around, as you've mentioned, it seems we need to open the rooms and see the updated information (both content and shape of the rooms) in our Floor layout.
Thank you,
Kind regards
(CID:126166818)
Hi Jarno,
Thank you,
Kind regards
(CID:126166818)
Posted: ‎2020-07-04 12:59 AM . Last Modified: ‎2023-10-22 02:06 AM
